[Qgis-user] Setting a line's length attribute
Micha Silver
micha at arava.co.il
Wed Mar 4 00:31:07 PST 2009
Thanks for the excellent example! One additional question (sorry for
hijacking the original post):
Andreas Neumann wrote:
> Hi,
> Here is some documentation:
> http://www.postgresql.org/docs/8.3/static/plpgsql.html (plpgsql) and
> http://www.postgresql.org/docs/8.3/static/plpgsql-trigger.html
> specifically for triggers.
> This would work for you (assuming that your geometry column is "the_geom"
> and the length columen is "object_length":
> CREATE FUNCTION update_length() RETURNS trigger AS $update_length$
> BEGIN
> NEW.object_length := ST_Length(NEW.the_geom);
> RETURN NEW;
> END;
> $update_length$ LANGUAGE 'plpgsql';
> CREATE TABLE test.test_lines
> gid serial NOT NULL,
> the_geom geometry,
> object_length numeric,
> CONSTRAINT pkey_test_lines_gid PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'LINESTRING'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 21781)
> WITH (OIDS=FALSE);
> CREATE INDEX in_test_test_lines_gist
> ON test.test_lines
> USING gist
> (the_geom);
> CREATE TRIGGER update_length_testlines
> BEFORE INSERT OR UPDATE
> ON test.test_lines
> FOR EACH ROW
> EXECUTE PROCEDURE update_length();
So, does this update the object_length column *both* on inserting a new
feature and on editing an existing feature?
Thanks again,
Micha
