[Qgis-user] Setting a line's length attribute
Andreas Neumann
a.neumann at carto.net
Wed Mar 4 02:17:08 PST 2009
Hi Micha,
It is updating on inserting and updating as in the example I set the
trigger on both insert and update.
I should note, however, that the length updates only after you saved the
layer in QGIS. QGIS does bulk saves/updates and not per individual row you
edited. This is something to keep in mind - maybe you wonder why it isn't
updating immediately after editing.
Andreas
On Wed, March 4, 2009 9:31 am, Micha Silver wrote:
> Thanks for the excellent example! One additional question (sorry for
> hijacking the original post):
> Andreas Neumann wrote:
>> Hi,
>> Here is some documentation:
>> http://www.postgresql.org/docs/8.3/static/plpgsql.html (plpgsql) and
>> http://www.postgresql.org/docs/8.3/static/plpgsql-trigger.html
>> specifically for triggers.
>> This would work for you (assuming that your geometry column is
>> "the_geom"
>> and the length columen is "object_length":
>> CREATE FUNCTION update_length() RETURNS trigger AS $update_length$
>> BEGIN
>> NEW.object_length := ST_Length(NEW.the_geom);
>> RETURN NEW;
>> END;
>> $update_length$ LANGUAGE 'plpgsql';
>> CREATE TABLE test.test_lines
>> gid serial NOT NULL,
>> the_geom geometry,
>> object_length numeric,
>> CONSTRAINT pkey_test_lines_gid PRIMARY KEY (gid),
>> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
>> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
>> 'LINESTRING'::text OR the_geom IS NULL),
>> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 21781)
>> WITH (OIDS=FALSE);
>> CREATE INDEX in_test_test_lines_gist
>> ON test.test_lines
>> USING gist
>> (the_geom);
>> CREATE TRIGGER update_length_testlines
>> BEFORE INSERT OR UPDATE
>> ON test.test_lines
>> FOR EACH ROW
>> EXECUTE PROCEDURE update_length();
> So, does this update the object_length column *both* on inserting a new
> feature and on editing an existing feature?
> Thanks again,
> Micha
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
