[Qgis-user] New PostGIS SQL Query Editor Plugin
John C. Tull
john.tull at wildnevada.org
Thu Mar 12 09:46:52 PDT 2009
Düster,
Do you have any documentation on how to use this? I gave it a go this
morning, but a simple query statement did not work. What would be a
snippet that would work in the query editor given that one has a table
called "example" in a database called postgis with public schema on a
local server?
Also, the plugin asks for a temporary directory to store files in, but
it seems that you need a permanent directory to work from. This is
where I am confused. Is this meant to perform queries on existing
postgis tables, or is it meant to query a shapefile and then load it
into postgis? If the former, how does it improve on adding a postgis
layer and performing the query there?
Cheers,
John
On Mar 12, 2009, at 1:36 AM, Düster Horst wrote:
> I just uploaded the new PostGIS SQL Query Editor Plugin to the QGIS
> User-Contributed Python Plugin Repository. The aim of the plugin is
> to edit and perform any spatial PostGIS query from an editor
> environment. After successful execution of a query the result will
> be loaded from shape file to MapCanvas. The plugin works provided
> that pgsql2shp is installed and the path to pgsql2shp is defined in
> the system PATH environment.
> I hope that the plugin will be helpful for you. I'm looking forward
> for any comment.
> Regards
> Dr. Horst Düster
> Stv. Amtschef / GIS-Koordinator
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090312/c7e2e52e/attachment.html>
