AW: Re: [Qgis-user] New PostGIS SQL Query Editor Plugin
John C. Tull
john.tull at wildnevada.org
Fri Mar 13 13:21:21 PDT 2009
On Mar 13, 2009, at 12:43 AM, Andreas Neumann wrote:
> Hi Horst,
> Thanks for providing this useful plugin.
> Following the discussion I suggest that you try using the
> MemoryProvider
> instead of Shapefiles. In many cases, one doesn't want to store the
> results of the query - so the memory provider would be a good place
> for
> the temporary storage of the result.
> If the user wants to store the results he can still write it to a
> shapefile or to Postgis.
> Here is some sample code for the MemoryProvider:
> http://wiki.qgis.org/qgiswiki/PythonBindings
> (search for memory provider)
> I haven't used it myself, but it looks like a perfect thing to use for
> your plugin.
+1
