[Qgis-user] Where is the plugin installer in 1.0.1 Kore? [SOLVED]
Alex Mandel
tech_dev at wildintellect.com
Tue Mar 31 16:26:32 PDT 2009
Nikos Alexandris wrote:
> On Wed, 2009-04-01 at 01:00 +0200, Nikos Alexandris wrote:
>> Alex:
>>> Did you install the python-qgis packages, they are not selected
>>> automatically when you install qgis.
>> Alex, I remind you that I did a clean install of everything and I did
>> _not_ install python-qgis. I just tried to do so and the message I get
>> is that pythong-qgis is already the newest version!
>> So, it's something else probably.
> Indeed, it's not python-qgis missing but _python-qgis-common_. It works
> now. Thanks for the pointing to the right direction.
> Shouldn't that be installed along with all other dependencies?
> Cheers, Nikos
Ya this one has been throwing me since 0.11, but python-qgis and
python-qgis-common (which is new) are optional packages and if you do an
upgrade on python-qgis it apparently isn't checking for -common too
since that us a dependency. I'll look at it some more and discuss with
the developers since this one seems to bite at least 3 new people every
version.
Thanks,
Alex
