[Qgis-user] Print Composer on OS X
John C. Tull
john.tull at wildnevada.org
Mon May 11 08:27:52 PDT 2009
If I understand you correctly, I believe you simply need to place the
cursor on the composer display and draw your rectangle. You will see a
rectangle item that can be changed to "cache" under the item tab to
view the current map canvas in your composer window. You can also make
other changes to that item, like removing the frame, setting
transparency, scale, size, etc.
Hope that helps,
John
On May 10, 2009, at 8:51 PM, Kurt Springs wrote:
> I am having trouble placing map layers into the Print Composer on OS
> X. I click on the "add new map" button on the Print Composer, but
> get no further windows to add the map layers. Am I missing
> something? How is this supposed to work?
> Any help would be appreciated.
> Qgis-user mailing list
