[Qgis-user] Maximum length for text attribute in shape?
Alex Mandel
tech_dev at wildintellect.com
Tue May 12 01:55:54 PDT 2009
What version of QGIS, which Operating System and if you know what
version of GDAL.
We'll need that info to try and repeat the issue.
Thanks,
Alex
Michael Pfeiffer wrote:
> Hi Alex
> thanks for answering.
> two ways how I get the result:
> a) Make a new empty Shapefile and generate a string attribute.
> Trying to write more than 80 signs doesn't work.
> b) Load a database layer with a attribute having more than 80 signs.
> Convert it to a Shapefile.
> The text is cut off after 80 signs.
> So it seems to be a Qgis problem and not a format problem.
>>> Hi list,
>>> is it possible that the maximum length of a text attribute (Shape Format)
>>> is
>>> limited to 80 signs?
>>> Or am I doing sth wrong?
>>> If not why is it limited to 80 signs and not to the normal 254 dbf signs?
>>> We are using Version 10691.
>>> thx
>>> Michael
>> It's important to remember that each file type has it's own limitations.
>> In the case of the shapefile there are all sorts of known and unknown
>> things.
>> http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Geoprocessing%20considerations%20for%20shapefile%20output
>> That said it is odd that it would be limited to 80 characters.
>> What we're you doing to discover this? Please describe the function
>> tools and procedures you used that made you think it was not taking more
>> than 80 characters.
>> We're you editing data in QGIS, or just viewing data? Or did you edit
>> the dbf in something else?
>> Thanks,
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
