[Qgis-user] Re: Plans to improve manage-R
Carson Farmer carson.farmer at gmail.com
Mon May 18 17:24:01 PDT 2009
Nikos,
> I want to ask if you plan to improve manage-R:
> * command syntax support/highlighting
> * command auto-complete function
> * customisable appearance (font shape/size, background color, etc. --
> separate from default qt-config)
I know this email was from a while back, but I thought I'd let you know
that manageR now has some simple syntax highlighting capabilities, as
well as basic code completion. Both are configurable via the config.ini
file located in the manageR directory.
Basically, your config file looks like this:
[general]
version: 0.6.8
description: Interface to the R statistical programming language
author: Carson J. Q. Farmer <carson.farmer at gmail.com>
qgisMinimumVersion: 1.0
theme: Classic
auto_completion: True
delay: 500
You can safely alter 'theme', 'auto_completion', and/or 'delay':
* 'theme' can be one of four different syntax highlighting themes
(Classic, Matrix, Cobalt, and Oblivion).
* 'auto_completion' should be either True (use autocompletion), or False
(don't use autocompletion).
* 'delay' simply specifies the time (in milliseconds) before suggestions
are given when typing text.
Eventually, I'll make it easier to customise these things, but for now I
think the config file is the best way to go.
Hopefully these improvements work ok for you, and please let me know if
you think of any other useful additions to manageR!
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
National University of Ireland, Maynooth,
Email: Carson.Farmer at gmail.com
Web:   http://www.carsonfarmer.com/
       http://www.ftools.ca/
