[Qgis-user] Re: Plans to improve manage-R
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue May 19 03:11:09 PDT 2009
Nikos:
> > I want to ask if you plan to improve manage-R:
> > * command syntax support/highlighting
> > * command auto-complete function
> > * customisable appearance (font shape/size, background color, etc. --
> > separate from default qt-config)
Carson F:
> I know this email was from a while back, but I thought I'd let you know
> that manageR now has some simple syntax highlighting capabilities, as
> well as basic code completion.
Hi Carson. Very kind of you to keep us informed. I've just tried to
update the plugin and I get the following message:
" Failed to unzip the plugin package. Probably it's broken or missing
from the repository. You may also want to make sure that you have write
permission to the plugin directory:
/home/nik/.qgis/python/plugins "
I'll double-check if I have messed something up. If anyone else has
already seen this and found the way around could you please post it
here?
Thanks, Nikos
