[Qgis-user] gps plugin
mtnbiketrail at zzz.com
Sat May 30 09:36:09 PDT 2009
Thanks for clearing that up. I'm using a geotiff from California, Albers
Equal Area, NAD83, and coords show as -268867,392264. No matter what I
tried, I could not get the gpx to plot over the geotiff, even with
projection on the fly. I wish I knew how to get the geotiff in clean.
I ended up using a jpeg of the geotiff with no coords and
georeferencing, then used a delimited text plugin of the gpx extract it
to make it work.
Tom
Alex Mandel wrote:
> It's working for me, with the attached file.
> Also note that -123,41 is the correct order in QGIS. Which means if
> you're expecting 41, -123 that does not exist and never will exist.
> My guess is that your raster is in a different projection, which means
> you need to turn projection on the fly on and project your map to the
> raster's projection. What are the coordinates when you zoom to the
> extent and hover over the raster?
> Alex
> mtnbiketrail at zzz.com wrote:
>> I'm saying this is a bug with the gps plugin. I downloaded a couple of gpx samples off the Internet. All files show lat first, then lon, but the Qgis gps plugin reverses them; uses the lat as lon and lon as lat. Ilooked at the gpx schema and the files I used look like they conform to the schema.
>> Tom
