[Qgis-user] ManageR not running
Agustin Lobo alobolistas at gmail.com
Sun May 31 02:02:56 PDT 2009
Gavin,
For installing rpy2 on ubuntu 8.04 I followed
http://rpy.sourceforge.net/rpy2/doc/html/overview.html#installation:
"To install from a downloaded source archive <rpy_package> do in a shell:
tar -xzf <rpy_package>.tar.gz
cd <rpy_package>
python setup.py install
and the rpy2 installation worked fine.
Nevertheless, manageR complained about QXmlStreamReader, as described here:
http://n2.nabble.com/Error-at-starting-manageR-tt2956781.html
Workaround sugested by Carson while he finds a final fix:
> I'm still working on this, but I don't know what is causing this
> error. Technically, the QXmlStreamReader is part QtCore, so I don't
> really know why this isn't working...
> For now, if you simply change the auto_completion variable in your
> config.ini file located in your manageR directory from commands.xml to
> Auto, manageR will skip the xml parsing step, and simply read the
> autocommands from your default R environment (i.e. the auto complete
> suggestions will be based on the packages you have set to
> automatically load when R is loaded (base, graphics, stats, etc.).
Also remember you need libqt4-xml:
$ sudo apt-get install libqt4-xml
Agus
Gavin Fleming wrote:
> I’m running Ubuntu 8.04 and to get the ManageR plugin to work I used
> easy_install to install rpy2 as apt-get could not find python-rpy2.
> Now when I try to run ManageR I get this error: RRuntimeError: Error
> in eval(expr, envir, enclos) : could not find function "lsf.str"
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/gavinf/.qgis//python/plugins/manageR/manageR.py", line 50,
> in run
> d = manageRDialog.manageR( self.iface, self.version )
> File "/home/gavinf/.qgis//python/plugins/manageR/manageRDialog.py",
> line 69, in __init__
> completer = CommandCompletion( self.wgt_console,
> self.getDefaultCommands(), delay, self.label )
> line 483, in getDefaultCommands
> info = robjects.r('lsf.str("package:' + package + '" )')
> File "build/bdist.linux-i686/egg/rpy2/robjects/__init__.py", line 535,
> in __call__
> File "build/bdist.linux-i686/egg/rpy2/robjects/__init__.py", line 422,
> in __call__
> RRuntimeError: Error in eval(expr, envir, enclos) : could not find
> function "lsf.str"
> Python version:
> 2.5.2 (r252:60911, Jul 31 2008, 17:44:49)
> [GCC 4.2.3 (Ubuntu 4.2.3-2ubuntu7)]
> Python path:['/usr/share/qgis/python',
> '/home/gavinf/.qgis//python/plugins/symbology_ng',
> '/home/gavinf/.qgis//python/plugins',
> '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.5/site-packages/rpy2-2.0.4-py2.5-linux-i686.egg',
> '/usr/lib/python2.5/site-packages', '/home/gavinf',
> '/home/gavinf/software/OpenOPC-1.1.6/src', '/usr/lib/python25.zip',
> '/usr/lib/python2.5', '/usr/lib/python2.5/plat-linux2',
> '/usr/lib/python2.5/lib-tk', '/usr/lib/python2.5/lib-dynload',
> '/usr/local/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages/Numeric',
> '/usr/lib/python2.5/site-packages/PIL',
> '/var/lib/python-support/python2.5',
> '/var/lib/python-support/python2.5/gtk-2.0',
> '/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode',
> '/home/gavinf/.qgis/python/plugins/fTools/tools']
> Any tips?
> thanks
> Gavin
> Qgis-user mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090531/908e4a62/attachment.vcf>
