[Qgis-user] qgis & mrsid used to work
M S
mseibel at gmail.com
Mon Nov 2 11:11:45 PST 2009
Great, thanks. This may only be on the 64bit platform, as I did the
same update this morning on a Karmic 32bit system, and the MRSID still
works.
Originally I installed karmic 64bit, then updated all. Then I added
the qgis/stable and ubuntugis/unstable, and wound up with a qgis
installation that wouldnt work with mr sid. (the gdal1.5.0 issue
perhaps?)
When I took out the qgis/stable, and only used ubuntugis/unstable, I
did get a qgis that could use SIDs. It looks like last night there
was an update to the ubuntugis? and when i updated/upgraded, then the
mrsid didnt work on Karmic 64bit.
Interestingly, I upgraded on Karmic qgis and grass (same versions
though?) this morning also on karmic 32bit, and mrsid still worked.
Much thanks,
Mark
On Mon, Nov 2, 2009 at 2:03 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> That to me sounds like you've got the QGIS repos and the UbuntuGIS
> repos. UbuntuGIS should be pulling 1.6.x I will double check with them,
> since I do recall in some recent past versions there being an error in
> the dependency list that still had 1.5 for QGIS.
> Alex
> M S wrote:
>> gdalinfo --version returns GDAL 1.6.2
>> if I do 'sudo apt-get remove gdal1-1.5.0' it wants to remove all this:
>> The following packages were automatically installed and are no longer required:
>> proj libgdal1-1.6.0-grass
>> Use 'apt-get autoremove' to remove them.
>> The following packages will be REMOVED:
>> libgdal1-1.5.0 libqgis1.3.0 python-qgis python-qgis-common qgis
>> qgis-common qgis-plugin-grass qgis-plugin-grass-common
>> And if I 'apt-get install qgis', it wants to put gdal 1.5.0 back.
>> Is there something with the ubuntugis/unstable repo perhaps?
>> Thanks,
>> Mark
>> On Mon, Nov 2, 2009 at 1:35 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> M S wrote:
>>>> I had a working QGIS and Mr SID, but just did an update to Karmic
>>>> which installed new qgis and grass (same versions?) and subsequently
>>>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
>>>> I am using this site to install
>>>> http://n2.nabble.com/Directions-to-get-mrsid-support-in-GQIS-and-other-packages-using-gdal-on-Ubuntu-td3169342.html
>>>> Everything seems fine with the creation of gdal_MrSID.so.
>>>> gdal_GRASS.so, gdal_MrSID.so and ogr_GRASS.so are all in the
>>>> /usr/lib/gdal16plugins directory. nothing is in the
>>>> /usr/lib/gdal15plugins directory.
>>>> I notice that libgdal1.5 gets installed from the ubuntu repo, while
>>>> additionally libgdal1.6 gets installed from the ubuntugis directory.
>>>> gdalinfo --formats lists MR SID as a recognized format, but QGIS
>>>> doesnt have it in the list nor recognizes it as GDAL raster.
>>>> Thanks,
>>>> Mark
>>> Which gdalinfo are you using. Good chance you installed it for libgdal
>>> 1.5 instead of 1.6. Try removing all the 1.5 stuff and redo the MRSID
>>> install.
>>> Alex
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
