[Qgis-user] qgis & mrsid used to work
Jürgen E. Fischer jef at norbit.de
Mon Nov 2 12:12:38 PST 2009
Hi Mark,
On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
> I had a working QGIS and Mr SID, but just did an update to Karmic
> which installed new qgis and grass (same versions?) and subsequently
> broke the mr sid relationship (I cant add MR SIDs to QGIS).
ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is build
with it.
The qgis repository has a karmic version, but is build against plain ubuntu and
therefore only supports the version in plain ubuntu (AFAIK 1.5).
You should not mix both.
So to my knowledge you can't currently have QGIS with GDAL 1.6 on karmic unless
you build GDAL and QGIS (packages) yourself.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
