[Qgis-user] qgis & mrsid used to work
M S
mseibel at gmail.com
Mon Nov 2 12:23:54 PST 2009
What is odd, is as of last friday, I had both QGIS Mimas and GDAL1.6.0
installed and working with mrsid, on 64bit Karmic and 32bit Karmic.
This morning an update was applied for qgis and grass, and mrsid with
QGIS stopped working on the 64bit platform. Interestingly, on 32bit
Karmic, my QGIS is still working with GDAL 1.6.0 and MRSID.
As a user, I dont fully understand the packaging and linking. Does
this page indicate there are Karmic qgis, grass and gdal packages?
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable looks
like the qgis-karmic was updated 20 hours ago if I understand that
correctly.
Initially, I had qgis/stable PPA and ubuntugis/unstable PPA in the
sources.list, so perhaps I goofed something up.
Thanks much for the help and information.
Mark
On Mon, Nov 2, 2009 at 3:12 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Mark,
> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>> I had a working QGIS and Mr SID, but just did an update to Karmic
>> which installed new qgis and grass (same versions?) and subsequently
>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is build
> with it.
> The qgis repository has a karmic version, but is build against plain ubuntu and
> therefore only supports the version in plain ubuntu (AFAIK 1.5).
> You should not mix both.
> So to my knowledge you can't currently have QGIS with GDAL 1.6 on karmic unless
> you build GDAL and QGIS (packages) yourself.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
