[Qgis-user] qgis & mrsid used to work
    M S
    mseibel at gmail.com
    Mon Nov  2 12:57:42 PST 2009
Is there a way to query which GDAL version QGIS 1.3.0 binary was built
against?  I have one working with MRSID (64bit) and one not (32bit).
I thought both had come from ubuntugis/unstable.
Thanks,
Mark
On Mon, Nov 2, 2009 at 3:23 PM, M S <mseibel at gmail.com> wrote:
> What is odd, is as of last friday, I had both QGIS Mimas and GDAL1.6.0
> installed and working with mrsid, on 64bit Karmic and 32bit Karmic.
> This morning an update was applied for qgis and grass, and mrsid with
> QGIS stopped working on the 64bit platform.  Interestingly, on 32bit
> Karmic, my QGIS is still working with GDAL 1.6.0 and MRSID.
> As a user, I dont fully understand the packaging and linking.  Does
> this page indicate there are Karmic qgis, grass and gdal packages?
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable   looks
> like the qgis-karmic was updated 20 hours ago if I understand that
> correctly.
> Initially, I had qgis/stable PPA and ubuntugis/unstable PPA in the
> sources.list, so perhaps I goofed something up.
> Thanks much for the help and information.
> Mark
> On Mon, Nov 2, 2009 at 3:12 PM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Mark,
>> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>>> I had a working QGIS and Mr SID, but just did an update to Karmic
>>> which installed new qgis and grass (same versions?) and subsequently
>>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
>> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is build
>> with it.
>> The qgis repository has a karmic version, but is build against plain ubuntu and
>> therefore only supports the version in plain ubuntu (AFAIK 1.5).
>> You should not mix both.
>> So to my knowledge you can't currently have QGIS with GDAL 1.6 on karmic unless
>> you build GDAL and QGIS (packages) yourself.
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>> Software Engineer         D-26506 Norden               http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
