[Qgis-user] qgis & mrsid used to work
MS
mseibel at gmail.com
Mon Nov 2 13:54:23 PST 2009
Hi Jürgen. Thanks for the explanation.
Does that mean the directions in link posted below are not applicable
for qgis/mrsid?
The link that explains the build against the sid SDK.
Mark
On Nov 2, 2009, at 3:12 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Mark,
> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>> I had a working QGIS and Mr SID, but just did an update to Karmic
>> which installed new qgis and grass (same versions?) and subsequently
>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein
> is build
> with it.
> The qgis repository has a karmic version, but is build against plain
> ubuntu and
> therefore only supports the version in plain ubuntu (AFAIK 1.5).
> You should not mix both.
> So to my knowledge you can't currently have QGIS with GDAL 1.6 on
> karmic unless
> you build GDAL and QGIS (packages) yourself.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-2
> 0
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-5
> 0
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und
> Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
