[Qgis-user] qgis & mrsid used to work
Agustin Lobo
alobolistas at gmail.com
Tue Nov 3 01:05:14 PST 2009
Mark,
which link?
Agus
MS wrote:
> Hi Jürgen. Thanks for the explanation.
> Does that mean the directions in link posted below are not applicable
> for qgis/mrsid?
> The link that explains the build against the sid SDK.
> Mark
> On Nov 2, 2009, at 3:12 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Mark,
>> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>>> I had a working QGIS and Mr SID, but just did an update to Karmic
>>> which installed new qgis and grass (same versions?) and subsequently
>>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
>> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is
>> build
>> with it.
>> The qgis repository has a karmic version, but is build against plain
>> ubuntu and
>> therefore only supports the version in plain ubuntu (AFAIK 1.5).
>> You should not mix both.
>> So to my knowledge you can't currently have QGIS with GDAL 1.6 on
>> karmic unless
>> you build GDAL and QGIS (packages) yourself.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-20
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
