[Qgis-user] qgis & mrsid used to work
M S mseibel at gmail.com
Tue Nov 3 04:05:21 PST 2009
My apologies, I was on my mobile and falsey assumed the trail of email
had the link on the bottom I had been using to setup QGIS and MRSID
GDAL.
http://n2.nabble.com/Directions-to-get-mrsid-support-in-GQIS-and-other-packages-using-gdal-on-Ubuntu-td3169342.html
Thanks to the entire community for all contributions and help.
Mark
On Tue, Nov 3, 2009 at 4:05 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Mark,
> which link?
> Agus
> MS wrote:
>> Hi Jürgen.  Thanks for the explanation.
>> Does that mean the directions in link posted below are not applicable for
>> qgis/mrsid?
>> The link that explains the build against the sid SDK.
>> Mark
>> On Nov 2, 2009, at 3:12 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
>>> Hi Mark,
>>> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>>>> I had a working QGIS and Mr SID, but just did an update to Karmic
>>>> which installed new qgis and grass (same versions?) and subsequently
>>>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
>>> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is
>>> build
>>> with it.
>>> The qgis repository has a karmic version, but is build against plain
>>> ubuntu and
>>> therefore only supports the version in plain ubuntu (AFAIK 1.5).
>>> You should not mix both.
>>> So to my knowledge you can't currently have QGIS with GDAL 1.6 on karmic
>>> unless
>>> you build GDAL and QGIS (packages) yourself.
>>> Jürgen
>>> Jürgen E. Fischer         norBIT GmbH               Tel.
>>> +49-4931-918175-20
>>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>>> +49-4931-918175-50
>>> Software Engineer         D-26506 Norden
>>> http://www.norbit.de
>>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>>> Rheinstrasse 13, 26506 Norden
>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
