[Qgis-user] .debs for latest proj, geos, gdal, grass64, gdal-grass-plugin, qgis_unstable under Karmic-64
Alex Mandel
tech_dev at wildintellect.com
Mon Nov 2 21:22:36 PST 2009
I would say yes and no. The normal place for this stuff is on the
Ubuntugis repo, but those packages should be done via normal Ubuntu
packing policies as much as possible, so it's probably not a good idea
to upload checkinstall debs.
I would encourage you to join the ubuntugis email list and launchpad
team to help with the ongoing package maintenance. Jachym as far as I
know is still maintaining some packages in a repo but with our
encouragement is moving them to the ubuntugis so there's one place to go
for everything.
I'm still trying to wrap my head around the proper method for packing
too. Instructions can be found on both launchpad and the ubuntu help pages.
Thanks,
Alex
Νίκος Αλεξανδρής wrote:
> Under Ubuntu Karmic 64-bit, I have used checkinstall after compiling
> latest proj, geos, gdal, grass64, gdal-grass-plugin and qgis_unstable
> for the installation. This created .deb packages [*].
> Now I tested installing the respective dependencies, a
> custom /etc/ld.so.conf file and then the "custom" debs in another
> machine and all seems to work fine.
> Is there any interest to test if this works on other Karmic's? Where
> could I potentially upload if there is any interest?
> @Jachym: do you still maintain debs?
> Best regards, Nikos
> [*] size - filename:
> 1.8M proj-from-source_4.6.1_amd64.deb
> 9.1M geos-from-source_3.1.1_amd64.deb
> 16.0M gdal-from-source_1.3.0-2_amd64.deb
> 16.0M grass64-release_6.4.0_amd64.deb
> 70.0K gdal-grass-from-source_1.4.3_amd64.deb
> 25.0M qgis_unstable_20091102_amd64.deb
> Qgis-user mailing list
