[Qgis-user] qgis & mrsid used to work
Agustin Lobo
alobolistas at gmail.com
Tue Nov 3 00:52:32 PST 2009
Jürgen E. Fischer wrote:
> Hi Mark,
> On Mon, 02. Nov 2009 at 13:29:31 -0500, M S wrote:
>> I had a working QGIS and Mr SID, but just did an update to Karmic
>> which installed new qgis and grass (same versions?) and subsequently
>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
> ubuntugis doesn't support karmic, but has GDAL 1.6 and qgis therein is build
> with it.
What does this mean? ubuntugis does not support karmic but there are
binary packages of gdal and qgis for karmic in the ubuntugis repository?
Agus
> The qgis repository has a karmic version, but is build against plain ubuntu and
> therefore only supports the version in plain ubuntu (AFAIK 1.5).
> You should not mix both.
> So to my knowledge you can't currently have QGIS with GDAL 1.6 on karmic unless
> you build GDAL and QGIS (packages) yourself.
> Jürgen
