[Qgis-user] Re: qgis on xubuntu 9.10 - won't start
Nik Go nikolai.go at gmail.com
Mon Nov 9 02:02:49 PST 2009
Okay, I think I'm on to something. After QGIS managed to launch I tried
re-installing the plugins I often use.
Trying to install geoprocessing plugin v0.52 causes QGIS to crash, and
causing a "Bus error" message. Attempts to re-launch qgis will not work
unless the geoprocessing plugin is removed. (Removed by manually deleting
the folder ~/.qgis/plugins/geoprocessing)
Hope this helps.
On Mon, Nov 9, 2009 at 2:44 PM, Nik Go <nikolai.go at gmail.com> wrote:
> I recently did a clean install of 64-bit Ubuntu 9.10. Qgis was working fine
> until i installed the xubuntu-desktop (well, at least that's the last thing
> I remembered installing.) and now I couldn launch qgis. No error message is
> displayed on the screen.
> Tried to do a backtrace but I get the following message:
>> "/usr/bin/qgis": not in executable format: File format not recognized
> Tried calling qgis from the command line and I get the following:
>>  Python support ENABLED :-)
> Loaded : fTools (package: fTools)
> Bus error
> And then it returns me to the $ prompt.
> Anybody else experiencing anything similar? Looking for pointers here.
> /r
> Nik
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091109/a0a8c963/attachment.html>
