[Qgis-user] Debugging QGIS using MSVC
Jürgen E. Fischer
jef at norbit.de
Wed Nov 11 13:45:00 PST 2009
Hi Rob,
On Wed, 11. Nov 2009 at 22:21:07 +0100, InterRob wrote:
> It has been quite a struggle to get QGIS to compile on my PC using MS
> Visual Studio 8 (2005). At the moment, it seems like all binaries compile
> correctly, but all in separate folders... Executing QGIS.exe (
> (...)\qgis-1.3.0\build\src\app\debug\qgis.exe) results in a message of
> missing dlls.
> How am I supposed to Run / Debug QGIS from MSVC? Pressing the "play"
> button, MSVC asks for which executable file to be used for the debug
> session.
You need to run the install target and run/debug the installed QGIS - and setup
your path to let it find the Qt dlls or copy the missing DLLs to QGIS' bin
directory.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
