[Qgis-user] Re: Azimuth and Distance Plugin (was Re: your old qgis plugins)
Maurício de Paulo
mauricio.dev at gmail.com
Thu Nov 12 07:59:29 PST 2009
Hi Darren,
Could you give me an example of the precision problem (azimuths and
distances).
Ah, the Zenith is a vertical angle measured from the terrain's normal vector
on the point i'm measuring.
In short, it's the vertical angle measured on old optical equipment. It's
there just to be a way of drawing 3D geometries (even though it's not really
available yet). At 90 degrees the line is drew on the horizontal plane.
Ok, I can see people have interests on different ways of input coordinates.
They're not as important as the bugs reported, but I'll keep an eye on these
sugestions. Maybe inserting a new box to let the user choose from many input
types. For now, let's work only with standard azimuth and let the user do
the conversions. At least until the plugin is working properly so I can
focus on new features.
One thing: The snap is already implemented. It worked fine here. I'm going
to try to reproduce the bug you reported but I'd really apreciate the data
you used as input. Is it possible?
Thanks for the inputs.
Mauricio de Paulo
2009/11/11 Darren Cope <darrencope at gmail.com>
> Hi Mauricio,
> I'm not 100% sure what is going on with the precision. I suspect the
> snapping feature will solve this, as the difference is quite small. I
> zoomed in to 2:1 (e.g. as far as I could) and clicked as close as I possibly
> could to a corner vertex, and then when I drew my feature, it doesn't line
> up (although the difference is minute in terms of actual distance)
> I guess I'm still not 100% clear on how the coordinates are entered. What
> does the 'zenith' column mean? I have a lot of plans that give angles
> relative to north or south (so they are displayed as Nxxdxx'xx"W or
> Sxxdxx'xx"E for example). I can convert these to a 360-based azimuth, but
> it would be nice to be able to enter these without doing any prior
> conversions.
> It looks like the zooming issue is fixed now!
> Thanks for all of your work on this--please let me know if I can provide
> any further information or testing for you.
> Cheers,
> Darren Cope
> http://dmcope.freeshell.org
> 2009/11/7 Maurício de Paulo <mauricio.dev at gmail.com>
>> Ok, thanks for the ideas. But could explain some of them to me?
>> What happened with the precision of the starting point? I've made some
>> tests here and the precision should be ok. I've made a teste with 0,0,0 and
>> it drew fine. Could you tell me how to reproduce the bug?
>> The snapping feature is my main priority now. I think this is a great
>> improvement.
>> DMS should be second in the list. But actually I need some inputs on how
>> is best entered a coordinate. We're talking about azimuth here. And a DMS
>> should have 3 numbers.
>> Something like 10o14'52'' is possible and easy for the user. Is it ok?
>> About the much larger extent... Hum... Fixed on zoom to selected feature.
>> I think that should solve it.
>> Gratefully
>> Maurício de Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091112/7f43e228/attachment.html>
