[Qgis-user] Re: Azimuth and Distance Plugin (was Re: your old qgis	plugins)
    Darren Cope
    darrencope at gmail.com
    Wed Nov 11 17:57:10 PST 2009
Hi Mauricio,
I'm not 100% sure what is going on with the precision. I suspect the
snapping feature will solve this, as the difference is quite small.  I
zoomed in to 2:1 (e.g. as far as I could) and clicked as close as I possibly
could to a corner vertex, and then when I drew my feature, it doesn't line
up (although the difference is minute in terms of actual distance)
I guess I'm still not 100% clear on how the coordinates are entered.  What
does the 'zenith' column mean?  I have a lot of plans that give angles
relative to north or south (so they are displayed as Nxxdxx'xx"W or
Sxxdxx'xx"E for example).  I can convert these to a 360-based azimuth, but
it would be nice to be able to enter these without doing any prior
conversions.
It looks like the zooming issue is fixed now!
Thanks for all of your work on this--please let me know if I can provide any
further information or testing for you.
Cheers,
Darren Cope
http://dmcope.freeshell.org
2009/11/7 MaurĂcio de Paulo <mauricio.dev at gmail.com>
> Ok, thanks for the ideas. But could explain some of them to me?
> What happened with the precision of the starting point? I've made some
> tests here and the precision should be ok. I've made a teste with 0,0,0 and
> it drew fine. Could you tell me how to reproduce the bug?
> The snapping feature is my main priority now. I think this is a great
> improvement.
> DMS should be second in the list. But actually I need some inputs on how is
> best entered a coordinate. We're talking about azimuth here. And a DMS
> should have 3 numbers.
> Something like 10o14'52'' is possible and easy for the user. Is it ok?
> About the much larger extent... Hum... Fixed on zoom to selected feature. I
> think that should solve it.
> Gratefully
> MaurĂcio de Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091111/90cc876f/attachment.html>
