[Qgis-user] qgis crash after window resize
    Ivan Mincik
    ivan.mincik at gista.sk
    Fri Nov 13 03:56:29 PST 2009
On Friday 13 November 2009, flavio rigolon wrote:
> Hi all,
>  and many thanks to all the contributors to this magic tool which is Qgis
> :-). In particular to the partecipant to the last hackfest!
> Here is my issue.
>  I've compiled qgis 1.4 r 12098 in debian (sid). I try to explain what
> happen:
> - run qgis -> the window isn't full size set. So I enlarge it (the enlarge
> button on the up right of it) and all is ok. Then I open a project and so
> on.
> - run qgis -> the window isn't full size set. I open a project with postgis
> layer connection; I enlarge the window and qgis crash with this console
> message:
> "Warning: QPaintDevice: Cannot destroy paint device that is being painted
> Segmentation fault"
> Qgis doesn't crash if the project doesn't contain postgis layer (only shape
> or GRASS data)
> Does anybody have the same problem?
Hi Flavio,
I have tried to compile the same revision on Debian Lenny. I can not reproduce your problem. Tested on 2 PostGIS polygon
layers.
Ivan
> Thanks to all
> flavio
Ivan Mincik
Gista s.r.o.
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091113/396de611/attachment.sig>
