[Qgis-user] Tema annotation
Werner Macho
werner.macho at gmail.com
Mon Nov 23 07:05:39 PST 2009
hi!
sounds like you are searching for the new labeling plugin from martin
but I'm not sure if it's available for 1.3.
probably you should try the new upcoming 1.4 out of trunk ..
regards
Werner
> Hello everyone.
> "" Does anyone know how to insert text in Qgis 1.3 MIMAS, as if it
> were a theme of "annotation" of esri? "
> In AutoCAD Map 3D, I exported a theme of "text". What happens is that
> when doing an "add vector layer in Qgis" the subject appears as dots.
> I gain access to the Layer Properties menu, I choose labels,
> placement, and text appears horizontal. Is there any tool or plugin to
> make the text automatically with the same orientation as the streets?
> Thank you for your help
> Orlando Bernardo
> Qgis-user mailing list
