[Qgis-user] Tema annotation
Bruce, Bob (CON) Bob.Bruce at gov.mb.ca
Mon Nov 23 07:46:12 PST 2009
Orlando, do you save the text orientation as an attribute in the SHAPE file?
I have cadastral data in SHAPE files that we create from our DXF files and save the orientation angle as an attribute TEXT_ANGLE. I then use this attribute in the "Data defined alignment" to individually orient each piece of text. In my case the text is actually line shapes but this will work just as well for text attributes contained in point shapes. Don't forget to turn off the drawing of the actual point in the symbology section of the layer properties (I set no pen for the fill and no line for the outline for this)
Bob Bruce
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of legio nostra
Sent: Monday, November 23, 2009 8:16 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Tema annotation
Olá a todos.
""Alguém sabe como inserir texto no Qgis 1.3 MIMAS, como se fosse um tema "annotation" da esri ?""
Em autocad map 3d, eu exportei um tema de "texto". O que acontece é que ao fazer um "add vector layer no Qgis" o tema aparece como pontos.
Eu acedo ao menu Properties do layer, eu escolho labels, placement, e o texto aparece sempre na horizontal. Existe alguma ferramenta ou plugin para colocar o texto automaticamente, com a mesma orientação que as ruas?
Muito obrigado pela ajuda
Orlando Bernardo
Hello everyone.
"" Does anyone know how to insert text in Qgis 1.3 MIMAS, as if it were a theme of "annotation" of esri? "
In AutoCAD Map 3D, I exported a theme of "text". What happens is that when doing an "add vector layer in Qgis" the subject appears as dots.
I gain access to the Layer Properties menu, I choose labels, placement, and text appears horizontal. Is there any tool or plugin to make the text automatically with the same orientation as the streets?
Thank you for your help
Orlando Bernardo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091123/4f413714/attachment.html>
