[Qgis-user] Break (split) a polygon with lines
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Tue Nov 24 07:24:11 PST 2009
Yes, its:
v.overlay
with default: operator=or
afterwards you can use
v.clean to remove dangles
and add centroids in areas where dangles have been.
Hope it helps,
Achim
Agustin Lobo schrieb:
> Is it possible to break a polygon into parts using another layer with
> lines that cross over the polygon?
> I've tried clip, but while I can clip the lines by the polygon, I cannot
> clip the polygon by the lines (which,
> in general, might make sense, probably what I need is not "clipping" but
> splitting).
> Thanks
> Agus
> Qgis-user mailing list
