[Qgis-user] Break (split) a polygon with lines
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Tue Nov 24 07:25:06 PST 2009
Oh, sorry!
Thought it was the GRASS-Mailing-List!
Achim
Achim Kisseler schrieb:
> Yes, its:
> v.overlay
> with default: operator=or
> afterwards you can use
> v.clean to remove dangles
> and add centroids in areas where dangles have been.
> Hope it helps,
> Achim
> Agustin Lobo schrieb:
>> Is it possible to break a polygon into parts using another layer with
>> lines that cross over the polygon?
>> I've tried clip, but while I can clip the lines by the polygon, I cannot
>> clip the polygon by the lines (which,
>> in general, might make sense, probably what I need is not "clipping" but
>> splitting).
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
