[Qgis-user] Problems at installing python plugins on 1.3.0 Mimas Windows - Standalone
Agustin Lobo
alobolistas at gmail.com
Fri Oct 2 01:03:59 PDT 2009
On behalf of Antonio Malo,
help appreciated.
(might be a problem with python versions installed by
gvsig and/or arcgis??)
Agus
-------- Original Message --------
Subject: Re: python plugin
Date: Fri, 2 Oct 2009 00:55:37 -0700 (PDT)
From: Antonio Malo <antoniojosemalo at yahoo.com.ar>
To: Agustin Lobo <aloboaleu at gmail.com>
References: <4AC5A6C3.3010007 at gmail.com>
Hi Agus:
I tried everything!!! Even uninstalling GVSIG and Arc GIS!!! Also I
installed and uninstalled QGIS several times and I downloaded a couple
of times the installation file!!!
Here are the answers to your questions:
*Are you following directions from
**http://sites.google.com/site/eospansite/gisbasic2009** ?
Yes, I am following exactly the directions
*Are you installing the version that is indicated there?
Yes, I intalled the 1.3.0 Mimas Windows - Standalone. I am working with
Windows XP-sp3.
*Does the problem occur at installing the plugin or at running the plugin?*
The problem occurs at the installation of the plug in:
I Install the plug-in (I have exactly the same problem with all of them)
and at the end of installation the program shows me the message: "The
pluigin is broken. Pithon said: no module named pointsamplingtool (this
name obviusly change for each plug-in)".
I assume that the plug in is installed, because at the bottom of the
window that shows me the message, the program suggest me to unistall the
plug in. If I don't uninstall it, the plug in list show this:
Status: invalid
Name: (for example) Point Sampling Tool
Version: ?
Description: This plugin is broken
*If the installation worked, did you restart the program before using
the plugin?*
Then I restart the program and I've got this message in several windows,
one window for one plugin:
Python error
Couldn't load plugin "pointsamplingtool" from ['C:/Archivos de
programa/Quantum GIS Mimas/./python', 'C:/Documents and
Settings/TOÃO/.qgis//python/plugins', 'C:/Archivos de programa/Quantum
GIS Mimas/./python/plugins', 'C:\Archivos de programa\Quantum GIS
Mimas\bin\python25.zip', '.\DLLs', '.\lib', '.\lib\plat-win',
'.\lib\lib-tk', 'C:\Archivos de programa\Quantum GIS Mimas\bin',
'C:\Archivos de programa\Quantum GIS Mimas\python\plugins\fTools\tools']
File "", line 2, in
ImportError: No module named pointsamplingtool
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
Python path:['C:/Archivos de programa/Quantum GIS Mimas/./python',
'C:/Documents and Settings/TO\xc3\x91O/.qgis//python/plugins',
'C:/Archivos de programa/Quantum GIS Mimas/./python/plugins',
'C:\\Archivos de programa\\Quantum GIS Mimas\\bin\\python25.zip',
'.\\DLLs', '.\\lib', '.\\lib\\plat-win', '.\\lib\\lib-tk', 'C:\\Archivos
de programa\\Quantum GIS Mimas\\bin', 'C:\\Archivos de programa\\Quantum
GIS Mimas\\python\\plugins\\fTools\\tools']
Thank you Agus
Antonio
