[Qgis-user] Problems at installing python plugins on 1.3.0 Mimas Windows - Standalone
Tim Sutton
lists at linfiniti.com
Sun Oct 4 13:38:00 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Agustin
Just for some feedback on this I tested in my xp virtual machine and
this plugins installed and run fine, without problems. This problem is
probably best reported to the plugin author to see if they can help.
Regards
Tim
Agustin Lobo wrote:
> On behalf of Antonio Malo,
> help appreciated.
> (might be a problem with python versions installed by
> gvsig and/or arcgis??)
> Agus
> -------- Original Message --------
> Subject: Re: python plugin
> Date: Fri, 2 Oct 2009 00:55:37 -0700 (PDT)
> From: Antonio Malo <antoniojosemalo at yahoo.com.ar>
> To: Agustin Lobo <aloboaleu at gmail.com>
> References: <4AC5A6C3.3010007 at gmail.com>
> Hi Agus:
> I tried everything!!! Even uninstalling GVSIG and Arc GIS!!! Also I
> installed and uninstalled QGIS several times and I downloaded a couple
> of times the installation file!!!
> Here are the answers to your questions:
> *Are you following directions from
> **http://sites.google.com/site/eospansite/gisbasic2009** ?
> Yes, I am following exactly the directions
> *Are you installing the version that is indicated there?
> Yes, I intalled the 1.3.0 Mimas Windows - Standalone. I am working with
> Windows XP-sp3.
> *Does the problem occur at installing the plugin or at running the plugin?*
> The problem occurs at the installation of the plug in:
> I Install the plug-in (I have exactly the same problem with all of them)
> and at the end of installation the program shows me the message: "The
> pluigin is broken. Pithon said: no module named pointsamplingtool (this
> name obviusly change for each plug-in)".
> I assume that the plug in is installed, because at the bottom of the
> window that shows me the message, the program suggest me to unistall the
> plug in. If I don't uninstall it, the plug in list show this:
> Status: invalid
> Name: (for example) Point Sampling Tool
> Version: ?
> Description: This plugin is broken
> *If the installation worked, did you restart the program before using
> the plugin?*
> Then I restart the program and I've got this message in several windows,
> one window for one plugin:
> Python error
> Couldn't load plugin "pointsamplingtool" from ['C:/Archivos de
> programa/Quantum GIS Mimas/./python', 'C:/Documents and
> Settings/TOÃO/.qgis//python/plugins', 'C:/Archivos de programa/Quantum
> GIS Mimas/./python/plugins', 'C:\Archivos de programa\Quantum GIS
> Mimas\bin\python25.zip', '.\DLLs', '.\lib', '.\lib\plat-win',
> '.\lib\lib-tk', 'C:\Archivos de programa\Quantum GIS Mimas\bin',
> 'C:\Archivos de programa\Quantum GIS Mimas\python\plugins\fTools\tools']
> Traceback (most recent call last):
> File "", line 2, in
> ImportError: No module named pointsamplingtool
> Python version:
> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> Python path:['C:/Archivos de programa/Quantum GIS Mimas/./python',
> 'C:/Documents and Settings/TO\xc3\x91O/.qgis//python/plugins',
> 'C:/Archivos de programa/Quantum GIS Mimas/./python/plugins',
> 'C:\\Archivos de programa\\Quantum GIS Mimas\\bin\\python25.zip',
> '.\\DLLs', '.\\lib', '.\\lib\\plat-win', '.\\lib\\lib-tk', 'C:\\Archivos
> de programa\\Quantum GIS Mimas\\bin', 'C:\\Archivos de programa\\Quantum
> GIS Mimas\\python\\plugins\\fTools\\tools']
> Thank you Agus
> Antonio
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkrJB6IACgkQqk07qZdiYjcJ0ACfQeh5o2w1pwloHmpJcVNmnAIg
0O8An2eeMCtclFXKs1VWOQ+ke5EGdo/Y
=clvi
-----END PGP SIGNATURE-----
