[Qgis-user] Problems at installing python plugins on 1.3.0 Mimas 	Windows - Standalone
    Agustin Lobo
    alobolistas at gmail.com
    Sun Oct  4 23:12:02 PDT 2009
Tim,
This is a problem with all python plugins. The problem only happens to 2
students
out of ~20 and seems related to the presence (even former presence) of
arcgis (which, I think, has it's own copy of python, am I wrong?). The
intriguing
point is that Antonio says that uninstalling arcgis does not solve the
problem.
Any hint appreciated.
Thanks
Agus
2009/10/4 Tim Sutton <lists at linfiniti.com>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Agustin
> Just for some feedback on this I tested in my xp virtual machine and
> this plugins installed and run fine, without problems. This problem is
> probably best reported to the plugin author to see if they can help.
> Regards
> Tim
> Agustin Lobo wrote:
> > On behalf of Antonio Malo,
> > help appreciated.
> > (might be a problem with python versions installed by
> > gvsig and/or arcgis??)
> > Agus
> > -------- Original Message --------
> > Subject:     Re: python plugin
> > Date:     Fri, 2 Oct 2009 00:55:37 -0700 (PDT)
> > From:     Antonio Malo <antoniojosemalo at yahoo.com.ar>
> > To:     Agustin Lobo <aloboaleu at gmail.com>
> > References:     <4AC5A6C3.3010007 at gmail.com>
> > Hi Agus:
> > I tried everything!!! Even uninstalling GVSIG and Arc GIS!!! Also I
> > installed and uninstalled QGIS several times and I downloaded a couple
> > of times the installation file!!!
> > Here are the answers to your questions:
> > *Are you following directions from
> > **http://sites.google.com/site/eospansite/gisbasic2009** ?
> > Yes, I am following exactly the directions
> > *Are you installing the version that is indicated there?
> > Yes, I intalled the 1.3.0 Mimas Windows - Standalone. I am working with
> > Windows XP-sp3.
> > *Does the problem occur at installing the plugin or at running the
> plugin?*
> > The problem occurs at the installation of the plug in:
> > I Install the plug-in (I have exactly the same problem with all of them)
> > and at the end of installation the program shows me the message: "The
> > pluigin is broken. Pithon said: no module named pointsamplingtool (this
> > name obviusly change for each plug-in)".
> > I assume that the plug in is installed, because at the bottom of the
> > window that shows me the message, the program suggest me to unistall the
> > plug in. If I don't uninstall it, the plug in list show this:
> > Status: invalid
> > Name: (for example) Point Sampling Tool
> > Version: ?
> > Description: This plugin is broken
> > *If the installation worked, did you restart the program before using
> > the plugin?*
> > Then I restart the program and I've got this message in several windows,
> > one window for one plugin:
> > Python error
> > Couldn't load plugin "pointsamplingtool" from ['C:/Archivos de
> > programa/Quantum GIS Mimas/./python', 'C:/Documents and
> > Settings/TOÃO/.qgis//python/plugins', 'C:/Archivos de programa/Quantum
> > GIS Mimas/./python/plugins', 'C:\Archivos de programa\Quantum GIS
> > Mimas\bin\python25.zip', '.\DLLs', '.\lib', '.\lib\plat-win',
> > '.\lib\lib-tk', 'C:\Archivos de programa\Quantum GIS Mimas\bin',
> > 'C:\Archivos de programa\Quantum GIS Mimas\python\plugins\fTools\tools']
> > Traceback (most recent call last):
> >   File "", line 2, in
> > ImportError: No module named pointsamplingtool
> > Python version:
> > 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> > Python path:['C:/Archivos de programa/Quantum GIS Mimas/./python',
> > 'C:/Documents and Settings/TO\xc3\x91O/.qgis//python/plugins',
> > 'C:/Archivos de programa/Quantum GIS Mimas/./python/plugins',
> > 'C:\\Archivos de programa\\Quantum GIS Mimas\\bin\\python25.zip',
> > '.\\DLLs', '.\\lib', '.\\lib\\plat-win', '.\\lib\\lib-tk', 'C:\\Archivos
> > de programa\\Quantum GIS Mimas\\bin', 'C:\\Archivos de programa\\Quantum
> > GIS Mimas\\python\\plugins\\fTools\\tools']
> > Thank you Agus
> > Antonio
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkrJB6IACgkQqk07qZdiYjcJ0ACfQeh5o2w1pwloHmpJcVNmnAIg
> 0O8An2eeMCtclFXKs1VWOQ+ke5EGdo/Y
> =clvi
> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091005/c0e54917/attachment.html>
