[Qgis-user] Problems at installing python plugins on 1.3.0 Mimas Windows - Standalone
Tim Sutton
lists at linfiniti.com
Mon Oct 5 04:04:30 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Werner Macho wrote:
> Hi!
> Yes ArcGIS brings it's own copy of Python with it (with ArcGIS 9.2 it is
> Python 2.4).
> And of course ArcGIS sets the System wide Path to it's own version of
> Python.
> Probably this PATH isn't cleaned out when uninstalling ArcGIS? I never
> tried it.
> I'd recommend investigating the PATH and uninstalling the Python24 from
> ArcGIS also - if it doesn't get uninstalled automatically by cleaning
> out arcgis..
Agustin if that is the case try typing
set
at the command prompt and look what it says for your python path. If it
shows some esri path then maybe you need to clear that in your system
settings. In a future package, I could try to set the python path to the
QGIS install dir before launching QGIS.
Regards
Tim
> good luck
> Werner
>> Tim,
>> This is a problem with all python plugins. The problem only happens to
>> 2 students
>> out of ~20 and seems related to the presence (even former presence) of
>> arcgis (which, I think, has it's own copy of python, am I wrong?). The
>> intriguing
>> point is that Antonio says that uninstalling arcgis does not solve the
>> problem.
>> Any hint appreciated.
>> Thanks
>> Agus
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkrJ0rcACgkQqk07qZdiYjet6gCeK6gfRNQCVqRSF5fa6B+VOM7e
qLwAoNmypk622myER6UjBktPiIj8Vvih
=FzO0
-----END PGP SIGNATURE-----
