[Qgis-user] Crash on continuous color legend type
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Wed Oct 7 23:48:10 PDT 2009
Hi Micha,
upgrade libgdal1.5 to 1.6 and all should be ok.
For packagers : using the qgis PPA repository on a fresh Jaunty installation,
qgis1.3 crashes like in this case because libgdal1.5 is installed by default.
The ubuntuGis PPA is ok and directly install the 1.6 version. Is it possible to
have the same versions on the differents repositories?
Thanks
Micha Silver a écrit :
> Giovanni Manghi wrote:
>> On Wed, 2009-10-07 at 18:11 +0200, Daniel Arribas-Bel wrote:
>>> Find attached a compressed files with one of the shapefiles I'm using
>>> (it fails with all I've tried though).
>>> Thanks a lot,
>> I'm not reproducing any crash here on ubuntu 9.04 and qgis 1.3
>> Try uninstalling everything and then make a clean install of the 1.3
>> version.
> No problems here using your shapefile. Fedora 10, QGIS 1.3.0
Lionel Roubeyrie - lroubeyrie at limair.asso.fr
Chargé d'études et de maintenance
LIMAIR - la Surveillance de l'Air en Limousin
http://www.limair.asso.fr
