[Qgis-user] Crash on continuous color legend type
Agustin Lobo
alobolistas at gmail.com
Thu Oct 8 00:09:06 PDT 2009
Lionel,
Which ppa do you refer to? There are 4 ppa repositories
with qgis binaries:
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
http://ppa.launchpad.net/qgis/stable/ubuntu
http://ppa.launchpad.net/qgis/unstable/ubuntu
http://ppa.launchpad.net/jef-norbit/qgis-unstable-ubuntugis-jef/ubuntu
Agus
Lionel Roubeyrie wrote:
> Hi Micha,
> upgrade libgdal1.5 to 1.6 and all should be ok.
> For packagers : using the qgis PPA repository on a fresh Jaunty
> installation, qgis1.3 crashes like in this case because libgdal1.5 is
> installed by default. The ubuntuGis PPA is ok and directly install the
> 1.6 version. Is it possible to have the same versions on the
> differents repositories?
> Thanks
> Micha Silver a écrit :
>> Giovanni Manghi wrote:
>>> On Wed, 2009-10-07 at 18:11 +0200, Daniel Arribas-Bel wrote:
>>>> Find attached a compressed files with one of the shapefiles I'm using
>>>> (it fails with all I've tried though).
>>>> Thanks a lot,
>>> I'm not reproducing any crash here on ubuntu 9.04 and qgis 1.3
>>> Try uninstalling everything and then make a clean install of the 1.3
>>> version.
>> No problems here using your shapefile. Fedora 10, QGIS 1.3.0
