[Qgis-user] Crash on continuous color legend type
Lionel Roubeyrie
lroubeyrie at limair.asso.fr
Thu Oct 8 00:14:12 PDT 2009
Augustin,
sorry to not mention them :
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu ==> libgdal1.6
http://ppa.launchpad.net/qgis/unstable/ubuntu ==> libgdal1.5
Agustin Lobo a écrit :
> Lionel,
> Which ppa do you refer to? There are 4 ppa repositories
> with qgis binaries:
> http://ppa.launchpad.net/qgis/stable/ubuntu
> http://ppa.launchpad.net/jef-norbit/qgis-unstable-ubuntugis-jef/ubuntu
> Agus
> Lionel Roubeyrie wrote:
>> Hi Micha,
>> upgrade libgdal1.5 to 1.6 and all should be ok.
>> For packagers : using the qgis PPA repository on a fresh Jaunty
>> installation, qgis1.3 crashes like in this case because libgdal1.5 is
>> installed by default. The ubuntuGis PPA is ok and directly install the
>> 1.6 version. Is it possible to have the same versions on the
>> differents repositories?
>> Thanks
>> Micha Silver a écrit :
>>> Giovanni Manghi wrote:
>>>> On Wed, 2009-10-07 at 18:11 +0200, Daniel Arribas-Bel wrote:
>>>>> Find attached a compressed files with one of the shapefiles I'm using
>>>>> (it fails with all I've tried though).
>>>>> Thanks a lot,
>>>> I'm not reproducing any crash here on ubuntu 9.04 and qgis 1.3
>>>> Try uninstalling everything and then make a clean install of the 1.3
>>>> version.
>>> No problems here using your shapefile. Fedora 10, QGIS 1.3.0
Lionel Roubeyrie - lroubeyrie at limair.asso.fr
Chargé d'études et de maintenance
LIMAIR - la Surveillance de l'Air en Limousin
http://www.limair.asso.fr
