[Qgis-user] Unable to start QGIS on windows
Carlos Dávila
cdavilam at jemila.jazztel.es
Fri Oct 9 09:17:38 PDT 2009
Craig Leat escribió:
> Carlos Dávila wrote:
>>> I have installed 1.3 using standalone installer in several windows
>>> machines and in most of them it works fine, but I have two with XP Home
>>> Edition SP2 where I only get the following message when I try to open
>>> QGIS:
> jef wrote:
>> >From the download page:
>>> Note: You may need to install the Microsoft C Runtime Libraries too. If QGIS
>>> does not start, get the MSVC libs from here[1] and install them before trying to
>>> run QGIS again.
>> Might that be the problem?
> Just to add that on my winxp pro machine I needed both the msvc++ 2005
> and 2008 packages.
I have already installed 2008 packages, but didn't work. I'll try adding
2005 and report.
Carlos
> Craig
