[Qgis-user] Re: Transformation beetween projections
    Goyo
    goyodiaz at gmail.com
    Tue Oct 13 16:27:04 PDT 2009
El mar, 13-10-2009 a las 18:52 +0200, Piotr Pachól escribió:
> Hello Alex and Borys,
> I attached 2 shp files in two projections EPSG 2180 and EPSG 2175.
> Each shape file contain 2 points with coordinates which should be (you can
> see coordinates also as columns of attributes).
> When you display these files in EPSG 2180 (with turning projection on the
> fly) data shift is approximately 130 metres.
> When you display these files in EPSG 2175 everything seems to be all right
> (data shift 0,02 meter).
I can confirm this using Mimas in Ubuntu 9.10.
> Prj files in both projections should be OK too.
Actually the srs definitions in your shapefiles are not the same as in
my database. Find attached the .prj files I get creating shapefiles in
EPSG:2175 and EPSG:2180, they are different than yours. Anyway I can
reproduce the same problem using them.
Goyo
Type: application/x-esri-crs
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091014/523f4b98/attachment.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091014/523f4b98/attachment-0001.bin>
