[Qgis-user] inserting symbols into qgis
James Card
James.Card at calcad.com
Thu Oct 15 11:50:59 PDT 2009
Inkscape also has an image tracing utility built-in to convert raster
images to vectors. If you're willing to do a bit of tinkering with the
conversion parameters I've had very good results with this process.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
On Thu, 15 Oct 2009 11:46:04 -0700, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> SVG is a hybrid format. It can also embed raster images (jpg,png). So
> theoretically you could embed your existing symbols in a raster (with a
> SVG shell around it). However, this is not recommended since the raster
> images don't scale properly. They would get pixely/or blurry when
> enlarged.
> SVG is the best choice for scalable symbols.
> If you want quick results and don't care about quality you could still
> embed the rasters (you can embed them base64 encoded in the data URL),
> so you only have one file and not two files. In Inkscape (at least in
> 0.47) you can embed the image in the SVG by using "Extensions" -->
> "Images" --> "Embed Images".
> Hope this helps,
> Andreas
> sunny74 wrote:
>> Hi Alex,Fischer
>> Thanks to both of you for your replies.
>> So I understand that only SVG files are accepted by QGIS as symbols.
>> Then I have to convert jpg,bmp etc into svg.
>> Do I have to use Inkscape i.e http://www.inkscape.org/ for the
>> conversion.
>> Warm Regards.
>> Jürgen E. Fischer wrote:
>>> Hi Alex,
>>> On Fri, 09. Oct 2009 at 07:44:43 -0700, Alex Mandel wrote:
>>>> In the QGIS installation folder there's a subfolder called svg. Any
>>>> svg
>>>> files you place in there will be picked up the next time QGIS is
>>>> started
>>>> and show up in the symbol picker.
>>> There's even a context menu in the symbol picker that allows a rescan
>>> without restarting.
>>> Jürgen
>>> -- Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-20
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> http://www.norbit.de
>>> -- norBIT Gesellschaft fuer Unternehmensberatung und
>>> Informationssysteme mbH
>>> Rheinstrasse 13, 26506 Norden
>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
