[Qgis-user] inserting symbols into qgis
sunny74 sb.ray at hotmail.com
Tue Oct 20 00:14:59 PDT 2009
Hi
Your suggestions did not work.
I converted my .jpg's into .svg's and placed them in  a separate folder
within the svg folder of QGIS but it did not show in symbology.
Then I put them in to one of the existing folders but again the same result,
even though I restarted QGIS.
there is a button called "Load Style" and I tried to use it to add symbols
but it required .qml files.
So how to add the symbols.
Regards.
James Card wrote:
> Inkscape also has an image tracing utility built-in to convert raster
> images to vectors. If you're willing to do a bit of tinkering with the
> conversion parameters I've had very good results with this process.
> James Card
> California CAD Solutions, Inc.
> 209-578-5580 - Voice
> 209-521-6493 - FAX
> On Thu, 15 Oct 2009 11:46:04 -0700, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> SVG is a hybrid format. It can also embed raster images (jpg,png). So
>> theoretically you could embed your existing symbols in a raster (with a
>> SVG shell around it). However, this is not recommended since the raster
>> images don't scale properly. They would get pixely/or blurry when
>> enlarged.
>> SVG is the best choice for scalable symbols.
>> If you want quick results and don't care about quality you could still
>> embed the rasters (you can embed them base64 encoded in the data URL),
>> so you only have one file and not two files. In Inkscape (at least in
>> 0.47) you can embed the image in the SVG by using "Extensions" -->
>> "Images" --> "Embed Images".
>> Hope this helps,
>> Andreas
>> sunny74 wrote:
>>> Hi Alex,Fischer
>>> Thanks to both of you for your replies.
>>> So I understand that only SVG files are accepted by QGIS as symbols.
>>> Then I have to convert jpg,bmp etc into svg.
>>> Do I have to use Inkscape i.e http://www.inkscape.org/ for the
>>> conversion.
>>> Warm Regards.
>>> Jürgen E. Fischer wrote:
>>>> Hi Alex,
>>>> On Fri, 09. Oct 2009 at 07:44:43 -0700, Alex Mandel wrote:
>>>>> In the QGIS installation folder there's a subfolder called svg. Any
>>>>> svg
>>>>> files you place in there will be picked up the next time QGIS is
>>>>> started
>>>>> and show up in the symbol picker.
>>>> There's even a context menu in the symbol picker that allows a rescan
>>>> without restarting.
>>>>  Jürgen
>>>> -- Jürgen E. Fischer         norBIT GmbH               Tel.
>>>> +49-4931-918175-20
>>>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>>>> +49-4931-918175-50
>>>> Software Engineer         D-26506 Norden
>>>> http://www.norbit.de
>>>> -- norBIT Gesellschaft fuer Unternehmensberatung und
>>>> Informationssysteme mbH
>>>> Rheinstrasse 13, 26506 Norden
>>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
View this message in context: http://n2.nabble.com/inserting-symbols-into-qgis-tp3787600p3857136.html
Sent from the qgis-user mailing list archive at Nabble.com.
