[Qgis-user] inserting symbols into qgis
Andreas Neumann
a.neumann at carto.net
Tue Oct 20 02:09:04 PDT 2009
hm - it sucessfully worked for me.
I see several potential causes for problems.
* Sometimes there are several parallel QGIS installations on your
harddrive. Make sure that the .svg files are placed in the correct
installation.
* your SVG images can't be loaded because they are invalid SVG. Do the
files properly open in a webbrowser?
* file permission problems?
Other than that it really should work.
Andreas
On Tue, October 20, 2009 9:14 am, sunny74 wrote:
> Hi
> Your suggestions did not work.
> I converted my .jpg's into .svg's and placed them in a separate folder
> within the svg folder of QGIS but it did not show in symbology.
> Then I put them in to one of the existing folders but again the same
> result,
> even though I restarted QGIS.
> there is a button called "Load Style" and I tried to use it to add symbols
> but it required .qml files.
> So how to add the symbols.
> Regards.
> James Card wrote:
>> Inkscape also has an image tracing utility built-in to convert raster
>> images to vectors. If you're willing to do a bit of tinkering with the
>> conversion parameters I've had very good results with this process.
>> James Card
>> California CAD Solutions, Inc.
>> 209-578-5580 - Voice
>> 209-521-6493 - FAX
>> On Thu, 15 Oct 2009 11:46:04 -0700, Andreas Neumann
>> <a.neumann at carto.net>
>> wrote:
>>> Hi,
>>> SVG is a hybrid format. It can also embed raster images (jpg,png). So
>>> theoretically you could embed your existing symbols in a raster (with a
>>> SVG shell around it). However, this is not recommended since the raster
>>> images don't scale properly. They would get pixely/or blurry when
>>> enlarged.
>>> SVG is the best choice for scalable symbols.
>>> If you want quick results and don't care about quality you could still
>>> embed the rasters (you can embed them base64 encoded in the data URL),
>>> so you only have one file and not two files. In Inkscape (at least in
>>> 0.47) you can embed the image in the SVG by using "Extensions" -->
>>> "Images" --> "Embed Images".
>>> Hope this helps,
>>> Andreas
>>> sunny74 wrote:
>>>> Hi Alex,Fischer
>>>> Thanks to both of you for your replies.
>>>> So I understand that only SVG files are accepted by QGIS as symbols.
>>>> Then I have to convert jpg,bmp etc into svg.
>>>> Do I have to use Inkscape i.e http://www.inkscape.org/ for the
>>>> conversion.
>>>> Warm Regards.
>>>> Jürgen E. Fischer wrote:
>>>>> Hi Alex,
>>>>> On Fri, 09. Oct 2009 at 07:44:43 -0700, Alex Mandel wrote:
>>>>>> In the QGIS installation folder there's a subfolder called svg. Any
>>>>>> svg
>>>>>> files you place in there will be picked up the next time QGIS is
>>>>>> started
>>>>>> and show up in the symbol picker.
>>>>> There's even a context menu in the symbol picker that allows a rescan
>>>>> without restarting.
>>>>> Jürgen
>>>>> -- Jürgen E. Fischer norBIT GmbH Tel.
>>>>> +49-4931-918175-20
>>>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>>>> +49-4931-918175-50
>>>>> Software Engineer D-26506 Norden
>>>>> http://www.norbit.de
>>>>> -- norBIT Gesellschaft fuer Unternehmensberatung und
>>>>> Informationssysteme mbH
>>>>> Rheinstrasse 13, 26506 Norden
>>>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> http://n2.nabble.com/inserting-symbols-into-qgis-tp3787600p3857136.html
> Sent from the qgis-user mailing list archive at Nabble.com.
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
