[Qgis-user] Display tooltips with attribute when moving over a feature
Andreas Neumann
a.neumann at carto.net
Sun Oct 18 04:41:07 PDT 2009
yes - as Boris indicated with the "Map Tips" Tool. If you use database
views you can even generate a view with a combination of several
attributes into one additional attribute to generate a multiline
tooltip, separated by \n
Andreas
Borys Jurgiel wrote:
> Dne neděle 18 října 2009 01:06:52 Intengu Technologies napsal(a):
>> Hi List
>> Is the a way that allows one to display tooltips for a selected
>> feature/s with attribute information as the mouse point moves over a
>> feature.
>> As an example you have loaded the continents of the world, when you
>> move your mouse over Africa - the name Africa is then displayed as a
>> tooltip.
> Sure, just enable it by pressing the button with a tooltip (between the
> measurement tools and bookmarks) and stop for a while over a feature.
> You can configure which attribute is displayed here:
> Layer properties -> General -> Options -> Display field.
> Qgis-user mailing list
