R: [Qgis-user] creating a point, free basemaps and going past 180 degrees
alessandro.sarretta at inwind.it alessandro.sarretta at inwind.it
Tue Oct 20 02:13:54 PDT 2009
For the first question:
convert your xls file in a txt or csv file, and then use the "Delimited text - Add delimitex text layer" plugin to view the data. That you convert it in a shapefile.
Hope this helps
Ale
----Messaggio originale---- Da: M.E.Dodd at open.ac.uk Data: 20/10/2009 10.48 A: "'qgis-user at lists.osgeo.org'"<qgis-user at lists.osgeo.org> Ogg: [Qgis-user] creating a point,	free basemaps and going past 180 degrees     --> -->
Three questions from someone newish to qgis:
how do you put point data on a map in qgis.  This seems to be the simplest thing to do in most other gis systems but the most  difficult in qgis or have I completely missed something.  E.g. I have a file of lat long coordinates or ordnance survey coordinates in an excel file and simply want to plot them out, how do I do that?  I have actually done it but only via another gis (then  saving and replotting the resulting vector format file in qgis) or via a .kml file again generated elsewhere.
how to get hold of free basemap outline data e.g. countries of the world.  I have tried very many different sources and still  not found a nice set of data that is relatively easy to use.
how to display and use maps that are not centred on the prime meridian and go past 180 degrees e.g. maps of Russia?
This is for a project to plot records of species in Russia i.e. plot the location of a sighting, seems straightforward enough but actually turns out to be very difficult.
Thanks
Mike
 The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091020/f68ee7c4/attachment.html>
