R: [Qgis-user] creating a point,	free basemaps and going past	180	degrees
    Micha Silver
    micha at arava.co.il
    Tue Oct 20 06:59:09 PDT 2009
alessandro.sarretta at inwind.it wrote:
> For the first question:
> convert your xls file in a txt or csv file, and then use the
> "Delimited text - Add delimitex text layer" plugin to view the data.
> That you convert it in a shapefile.
> Hope this helps
> Ale
For the second, try
http://www.gadm.org/
>     ----Messaggio originale----
>     Da: M.E.Dodd at open.ac.uk
>     Data: 20/10/2009 10.48
>     A: "'qgis-user at lists.osgeo.org'"<qgis-user at lists.osgeo.org>
>     Ogg: [Qgis-user] creating a point, free basemaps and going past
>     180 degrees
>     Three questions from someone newish to qgis:
>        1. how do you put point data on a map in qgis.  This seems to
>           be the simplest thing to do in most other gis systems but
>           the most difficult in qgis or have I completely missed
>           something.  E.g. I have a file of lat long coordinates or
>           ordnance survey coordinates in an excel file and simply want
>           to plot them out, how do I do that?  I have actually done it
>           but only via another gis (then saving and replotting the
>           resulting vector format file in qgis) or via a .kml file
>           again generated elsewhere.
>        2. how to get hold of free basemap outline data e.g. countries
>           of the world.  I have tried very many different sources and
>           still not found a nice set of data that is relatively easy
>           to use.
>        3. how to display and use maps that are not centred on the
>           prime meridian and go past 180 degrees e.g. maps of Russia?
>     This is for a project to plot records of species in Russia i.e.
>     plot the location of a sighting, seems straightforward enough but
>     actually turns out to be very difficult.
>     Thanks
>     Mike
>     The Open University is incorporated by Royal Charter (RC 000391),
>     an exempt charity in England & Wales and a charity registered in
>     Scotland (SC 038302).
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
