[Qgis-user] Re: Cartogram creator not working
    Rainer M Krug
    r.m.krug at gmail.com
    Tue Oct 27 07:33:32 PDT 2009
On Tue, Oct 27, 2009 at 4:31 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> True, I was using an inappropriate layer, sorry for the noise.
No problem - could the plugin check if the layer is a polygon layer?
> You should consider that sometimes 0 are present?
> (ZeroDivisionError: float division)
I agree - that should be checked and caught - I had the same error.
But I am also just a user and not the author.
Cheers,
Rainer
Agus
> Carson Farmer wrote:
>> Hi Agus,
>> The 'Generate Centroids' name is simply me reusing code, I'll fix this
>> later...
>> as for not being able to select anything, all I can think of is perhaps
>> you don't
>> have a valid polygon layer loaded, or if you do, perhaps it doesn't have
>> any numeric fields?
>> Carson
>> On Tue, Oct 27, 2009 at 8:13 AM, Agustin Lobo <alobolistas at gmail.com<mailto:
>> alobolistas at gmail.com>> wrote:
>>    Hi!
>>    When I run plugin Cartogram Creator a window named
>>    "Generate Centroids"
>>    pops up in which I cannot select anything in field
>>    Input Shapefile
>>    (qgis 1.3.0 ubuntu jaunty from ubuntugis-unstable binaries)
>>    Cheers
>>    Agus
>> Carson Farmer
>> National Centre for Geocomputation
>> John Hume Building,
>> National University of Ireland, Maynooth,
>> Maynooth,
>> Co. Kildare,
>> Ireland.
>> www.carsonfarmer.com <http://www.carsonfarmer.com>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Natural Sciences Building
Office Suite 2039
Stellenbosch University
Main Campus, Merriman Avenue
Stellenbosch
South Africa
Cell:           +27 - (0)83 9479 042
Fax:            +27 - (0)86 516 2782
Fax:            +49 - (0)721 151 334 888
email:          Rainer at krugs.de
Skype:          RMkrug
Google:         R.M.Krug at gmail.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091027/b31860b2/attachment.html>
