[Qgis-user] Re: Cartogram creator not working
Carson Farmer
carson.farmer at gmail.com
Tue Oct 27 07:58:08 PDT 2009
Hi guys,
No problem - could the plugin check if the layer is a polygon layer?
Yes, certainly, does it not already do this? I thought I had put this check
in, will fix later today if I have time...
>> You should consider that sometimes 0 are present?
>> (ZeroDivisionError: float division)
> I agree - that should be checked and caught - I had the same error.
> But I am also just a user and not the author.
Yes, this should probably be caught, though certainly not allowed... will
also add this check later...
At this stage, the plugin is really just a fun little tool for making
cartograms...
In fact, it's not even really the best cartogram algorithm out there...
Carson
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091027/09c6866b/attachment.html>
