[Qgis-user] wg84 projection problem
Otto Dassau otto.dassau at gmx.de
Thu Oct 29 01:30:35 PDT 2009
Hi Markus,
On Thu, 29 Oct 2009 14:32:16 +0700
Markus Nater <mark.nater at gmail.com> wrote:
> Hi List
> I have some polygons in qgis with wgs84 projection. But when I try to
> measure distance in meters, it gives me back 1cm for 0.1 degrees, which
> is of course totally wrong.
> how can I fix this, so I will have the correct measurements in meters?
you have to define:
a) settings => project properties => general => layer units (select meters)
b) settings => options => map tools => ellipsoid for distance calculation
to fit the ellipsoid used in your CRS.
> cheers
> markus
Regards,
 Otto
