[Qgis-user] wg84 projection problem
    Werner Macho
    werner.macho at gmail.com
    Thu Oct 29 01:37:18 PDT 2009
hi all
regarding setting b)
why is there a double entry of WGS84 in the Ellipsoid for distance
calculation? One at the top and one at the bottom ..
bug? feature?
greetings
Werner
> you have to define:
> a) settings => project properties => general => layer units (select meters)
> b) settings => options => map tools => ellipsoid for distance calculation
> to fit the ellipsoid used in your CRS.
