[Qgis-user] wg84 projection problem
Otto Dassau
otto.dassau at gmx.de
Thu Oct 29 02:07:43 PDT 2009
On Thu, 29 Oct 2009 15:54:44 +0700
Markus Nater <mark.nater at gmail.com> wrote:
> thank you Alex
> and thank you Otto
> when I do take a projected coord system (set to wgs84 zone 47N), the
> measurements are correct.
> but then arises a new problem, as I have a raster shaded relief as
> geotiff overlayed, that is referenced in wgs84. projection on the fly
> makes this raster invisible... strangely! and I havent found out how to
> work around this yet. i cant work out to reproject this raster either,
> somehow nothing ever happens using the gdal raster translation.
> any ideas how to solve this little problem? :-)
your data in "wgs84 zone 47N" is probably something like:
CRS: Projected Coordinate System "UTM zone 47N"
Ellipsoid: WGS84
=> EPSG: 32647 ?
and the WGS 84 raster might be:
CRS: Geographic Coordinate System "WGS84"
Ellipsoid: WGS 84
=> EPSG: 4326 ?
that would mean your 2 layers are projected in 2 different CRS.
QGIS supports OTF for vector layers. So you can load a raster, define its
CRS, activate OTF and then load a vector layer projected in another CRS.
Regards,
Otto
> cheers
> markus
> Alex Mandel schrieb:
> > Markus Nater wrote:
> >> Hi List
> >> I have some polygons in qgis with wgs84 projection. But when I try to
> >> measure distance in meters, it gives me back 1cm for 0.1 degrees, which
> >> is of course totally wrong.
> >> how can I fix this, so I will have the correct measurements in meters?
> >> cheers
> >> markus
> > Enable projection on the fly, and pick a projected coordinate system.
> > Technically in WGS84 the best you could get is great circle distances,
> > and I'm not sure the measure tool does this yet. So you need to be in a
> > projection that flattens the map evenly for distance measurement.
> > Alex
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
