[Qgis-user] wg84 projection problem
Markus Nater
mark.nater at gmail.com
Thu Oct 29 02:24:09 PDT 2009
I tried it in the python plugin and yes, it gives me
ERROR 1: Can't load requested DLL:
C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_ECW_JP2ECW.dll 126: Das
angegebene Modul wurde nicht gefunden.
which is probably my fault that I have not installed this yet.
thanks a lot for your tip about loading the raster first!
cheers
markus
Alex Mandel schrieb:
> Were you using GDAL Translate on the command line(if so what was the
> command you used?) or with the new GDAL Tools python plugin in QGIS? Did
> it give you an error or just fail to show up. I tend to start by
> importing the Raster 1st to make sure it's in the projection I want it
> in before overlaying Vectors.
> Alex
> Markus Nater wrote:
>> thank you Alex
>> and thank you Otto
>> when I do take a projected coord system (set to wgs84 zone 47N), the
>> measurements are correct.
>> but then arises a new problem, as I have a raster shaded relief as
>> geotiff overlayed, that is referenced in wgs84. projection on the fly
>> makes this raster invisible... strangely! and I havent found out how to
>> work around this yet. i cant work out to reproject this raster either,
>> somehow nothing ever happens using the gdal raster translation.
>> any ideas how to solve this little problem? :-)
>> cheers
>> markus
>>> Markus Nater wrote:
>>>> Hi List
>>>> I have some polygons in qgis with wgs84 projection. But when I try to
>>>> measure distance in meters, it gives me back 1cm for 0.1 degrees, which
>>>> is of course totally wrong.
>>>> how can I fix this, so I will have the correct measurements in meters?
>>>> cheers
>>>> markus
>>> Enable projection on the fly, and pick a projected coordinate system.
>>> Technically in WGS84 the best you could get is great circle distances,
>>> and I'm not sure the measure tool does this yet. So you need to be in a
>>> projection that flattens the map evenly for distance measurement.
>>> Alex
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091029/009a8b7b/attachment.html>
